Date/Time: Mon, 20 Jan 2025 16:48:22 +0000
Volume by Price Value Area % indication relative to POC
View Count: 1120
[2018-06-29 15:32:03]
User9890731 - Posts: 47
hi,
I would like to know if the VBP indicator could be coded to display the % distance of the VAl and VAh relative to the POC
in realtime as the poc shifts between the two value areas..
thanks..
Date Time Of Last Edit: 2018-06-29 17:06:07
imagepoc.png / V - Attached On 2018-06-29 15:31:08 UTC - Size: 21.44 KB - 273 views
[2018-06-29 21:43:21]
You can do this yourself. Use the Spreadsheet Formula and use the following formula for the Value Area High Percentage:
=(ID1.SG3 - ID1.SG2) / (ID1-SG3 - ID1.SG4)
Then add another Spreadsheet Formula and use the following formula for the Value Area Low Percentage:
=(ID1.SG2 - ID1.SG4) / (ID1.SG3 - ID1.SG4)
These assume that the Volume by Price study is ID1, so you would need to adjust as necessary.
You can then hide these Spreadsheet Formula studies and use the Text Display for Study to display the value on the chart.
[2018-06-29 22:10:51]
Ok thanks,
