Date/Time: Sat, 23 Nov 2024 05:50:21 +0000
[Programming Help] - Referencing prior bars in Studies
View Count: 1773
[2018-06-29 14:48:57] |
User360283 - Posts: 504 |
I want to reference prior data [-N] in studies such as Study Subgraph Add, Subtract, Multiply, etc. Using a negative displacement on the resulting plot only visually displays the plot as desired, but the correct data cannot be used to generate a signal without having the ability to reference prior data in the studies. Help please Thanks |
[2018-07-11 11:17:21] |
Waiting for an answer
[2018-07-11 22:44:57] |
This is possible and is explained here: Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-16 10:23:36] |
I want to reference prior data [-N] in studies such as Study Subgraph Add, Subtract, Multiply, etc. Please see enclosed snip. In the Study Subgraph Multiple I was trying to code the Input Data to be S5-Avg1[-1] This data is then used in additional formulas and is different from negative displacements. Thanks |
sierra snip.PNG / V - Attached On 2018-07-16 10:23:28 UTC - Size: 200.42 KB - 565 views |
