Date/Time: Mon, 20 Jan 2025 16:52:58 +0000
DVP permanently aligned right
View Count: 676
[2018-06-29 14:06:56] |
sjk - Posts: 43 |
No matter how many times I click NO in the box the profile aligns RIGHT. How do I fix that?
[2018-06-29 19:56:50] |
You may have set that Input to Yes as a default setting for the Volume by Price study, or you have set up a Study Collection to use as one of the drawing configurations with the Draw Volume Profile which has that Input set to Yes. Refer to: Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-07-01 00:02:41] |
sjk - Posts: 43 |
Thank you but try as I may the Apply or OK button switches right back to "right"
[2018-07-02 17:20:59] |
What we need you to do is to provide the chart with that volume by price study following these instructions and we will look at this: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
