Date/Time: Sun, 24 Nov 2024 08:49:19 +0000
Difficulty to make updating the graph that lacks a few days of data.
View Count: 1381
[2013-10-15 15:40:41] |
bercor - Posts: 30 |
I state that I use IB data. Opening for example eur / usd but it also happens with BUND or any financial instrument, am I the bank datiche is updated in real time but with a hole in the graph of several days. I go to EDIT, HISTORICAL DATA FOR DOWNLOAD ..... I select a few days prior to the hole, I click OK ... but nothing happens! It remains the hole in the graph ... How can I do? thanks |
sierra buco dati.png / V - Attached On 2013-10-15 15:40:10 UTC - Size: 44.01 KB - 420 views |
[2013-10-15 21:16:30] |
Please can anyone help me out in my initial question? are hours that I try to solve the problem but I can not find the solution ... Thanks to those who will want to give me a hand. |
[2013-10-15 21:31:55] |
You are not following the correct procedure for an Intraday chart. Refer to the instructions in help topic 7.1 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails7.html Also refer to help topic 37 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails37.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
