Date/Time: Tue, 22 Apr 2025 10:35:34 +0000
Trade Window for Chart - How to Change Font size
View Count: 2134
[2018-06-28 17:05:26]
User360283 - Posts: 514
Trade Window for Chart - How to Change Font size?
[2018-06-28 20:09:15]
This is considered a dialog type window. Refer to:
http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#AdjustingSizeOfDialogWindows
[2021-02-23 07:47:33]
User135370 - Posts: 162
Yes this is not so easy to fix through windows it affects everything else, can the trade window not be made independent, is this something Sierra can look at
[2021-09-20 14:01:11]
TropicalTrader - Posts: 45
Request: I wish you would make the text in the Trade Window adjustable without having to affect changing my screen size using windows controls. Everything was perfect on my screen except for the text in the trade window.. This should be adjustable imo.
[2021-09-20 16:26:23]
John - SC Support - Posts: 39395
We are working on changing all our dialog windows. The beginning of this are the Settings Windows, for which many have already been changed. Although the Trade Window will probably be one of the last, as it is one of the more complex ones, you will have greater control over the window when this work is done.
[2023-07-11 15:52:53]
Has this been updated yet? Using 4k monitors its really hard to see the text size on the trade window and its very important to see..
[2024-12-24 04:35:40]
User708541 - Posts: 135
Checking the status of changing the font size for trade window and other dialogue boxes. Can you please provide an update on this. Like last poster mentioned, using a 4K monitor makes the trade windows very small.
[2025-01-19 23:01:40]
Sierra_Chart Engineering - Posts: 19305
No, this is not yet completed for the Trade Window.
Date Time Of Last Edit: 2025-01-19 23:01:48
