Date/Time: Mon, 20 Jan 2025 17:02:07 +0000
commissions in trade activity log
View Count: 1443
[2018-06-28 16:18:10] |
User786248 - Posts: 25 |
Hello I am unable to display commissions when I open my trade activity log. This is the process I went through to enable commissions but still does not work. First, I went to global settings, symbols settings, find the instrument I trade which is F.US.ENQU18 and insert 4.08 under the commission box. Then I go to Trade/Activity log and make sure the commission box is checked. Then I apply and commissions still show as 0. Any help is appreciated. I am currently running AMPfutures via CQG fix data feed. thanks Date Time Of Last Edit: 2018-06-28 16:18:19
[2018-06-28 21:52:12] |
Xfanman1 - Posts: 320 |
It sounds like you're doing it correctly but compare your setup with my screen shots below. I use CQG Fix with AMP also. The second attachment shows 2 contracts round trip in NQ on CQG. -- Scott |
Commission Settings.PNG / V - Attached On 2018-06-28 21:51:54 UTC - Size: 44.22 KB - 418 views CommissionsTradeLog.PNG / V - Attached On 2018-06-28 21:52:01 UTC - Size: 70.81 KB - 364 views |
