Date/Time: Fri, 18 Apr 2025 02:46:50 +0000
Show/Hide specific study/s via a button on Control Bar 8
View Count: 3287
[2018-06-28 13:48:35] |
User92573 - Posts: 559 |
Dear Support Is there a way to show/hide specific studies via a button on control bar 8? Thank you. |
[2018-06-28 21:16:48] |
No, the only option is to Show/Hide All Studies. But, there is the ability to hide all the subgraphs for those studies that you do not want to show up. Refer to the documentation here for how to set this up: Chart Studies: Hiding Subgraphs to Prevent Display of Study when Unhiding Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-18 18:33:55] |
ganz - Posts: 1048 |
User92573 https://futures.io/sierra-chart/26630-hide-show-studies-buttons-study.html |
[2019-02-18 22:09:58] |
SC Support pls take a look at https://futures.io/sierra-chart/26630-hide-show-studies-buttons-study-5.html#post706947 what do you think? thnx. |
[2019-02-18 23:01:53] |
SC Support It would be better to have the info on all changes you've applied regarding users tools you've made |
[2019-02-18 23:19:00] |
Control bar buttons can be set up for Study Collections and then you can use those to apply a particular Study Collection to the chart which contains the studies you want to see at that moment: Study Collections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
