Date/Time: Mon, 20 Jan 2025 16:51:57 +0000
Text Background
View Count: 1024
[2018-06-27 21:43:31] |
User311951 - Posts: 31 |
Hi, When I implement Custom Studies and use Text as a draw style, the text on the chart usually has a white background - I'm assuming this makes it more visible among the clutter on the chart. Is it possible to remove that background so the text is not surrounded by a colour which sometimes covers other more important things on my chart? Thanks |
[2018-06-28 18:01:44] |
Use the "Transparent Text" Draw Style instead.
