Date/Time: Mon, 20 Jan 2025 14:02:18 +0000
1 second historic data
View Count: 658
[2018-06-27 20:45:11] |
User251539 - Posts: 1 |
I have linked my TD Ameritrade which provides historic data down to 1m/candle. What data source does Sierra Chart use for 1s/candle historic data? I do need to access 1 second per handle historic data for analysis, what package should I get then? |
[2018-06-27 21:25:34] |
Did you need one second data for stocks or futures?
