Date/Time: Sun, 24 Nov 2024 08:32:22 +0000
Horizontal Lines
View Count: 1130
[2013-10-15 14:01:03]
User23815 - Posts: 210
Is it possible to make the horizontal lines transparent, or to draw them underneath the main graph that they are set on? I know this can be done through the Horizontal Lines study but it seems it would be an attractive feature in the tool as well. thanks
[2013-10-15 15:22:43]
You can draw chart drawings underneath the main price graph. There is a setting for this in Chart >> Chart Settings >> Advanced Settings.
