Date/Time: Mon, 20 Jan 2025 16:57:47 +0000
one spreadsheet file / multiple charts and chartbooks
View Count: 1555
[2018-06-27 13:12:46]
User606491 - Posts: 164
Regarding spreadsheets:
1) What performance (or any other) issues arise, if I use one spreadsheet file across multiple charts within one chart book (i.e. one chart book / 3 charts / each chart using the same spreadsheet filename)
2) What performance (or any other) issues arise, if I use one spreadsheet file across multiple chartbooks (i.e. two chart books / each chartbook has 3 charts / all chartbooks and charts using the same spreadsheet name)
I ask because I notice some of my spreadsheets automatically switch between symbols. Is this just the nature of the spreadsheet or does this create a performance issue? Moreover, if the spreadsheets do switch, is it possible that an alert on one symbol may inadvertently trigger on another symbol?
Bottom line: should each spreadsheet in each chart / chart book have a different filename? That may get tedious.
thank you
[2018-06-29 14:37:42]
An update here would be greatly appreciated. Thank you.
[2018-06-29 15:57:25]
1, 2. This is just fine just make sure each Chart is using a separate Sheet within the same named Spreadsheet.
All of this is explained in detail here:
Spreadsheet Study Inputs: Chart Data Output Sheet Number
Date Time Of Last Edit: 2018-06-29 15:57:47
[2018-06-29 16:17:15]
Excellent. The highlighted section is very clear.
