Date/Time: Mon, 20 Jan 2025 17:04:09 +0000
Attached Orders - Option to adjust Parent Order while Child Orders remain locked in place
View Count: 743
[2018-06-27 11:15:18] |
User463572 - Posts: 4 |
I'd like to be able to move the parent order by dragging it on the chart without moving the attached child orders, is this possible? If not, could the functionality be added, for example by holding down a customisable key command before clicking and dragging the parent order.
[2018-06-28 13:58:00] |
No, this is not supported and it is not something we would likely add.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-28 13:58:14
