Date/Time: Sun, 24 Nov 2024 10:31:04 +0000
[User Discussion] - Cotton Continuous Function shows errors
View Count: 1453
[2013-10-15 11:36:25]
Paul.M - Posts: 113
Cotton Continuous Function shows data holes
please correct this.
http://www.sierrachart.com/image.php?l=1381836791626.png
Not sure if this setting is relevant - but the correct months are marked:
image2013-10-15_133436.jpg / V - Attached On 2013-10-15 11:36:06 UTC - Size: 195.41 KB - 496 views
[2013-10-15 11:58:00]
Paul.M - Posts: 113
This other Cotton Conti is also kaput.
http://www.sierrachart.com/image.php?l=1381838206363.png
[2013-10-21 10:15:29]
Paul.M - Posts: 113
any updates ?
[2013-10-22 17:39:51]
Paul.M - Posts: 113
same issue with Continuous Gold:
http://www.sierrachart.com/image.php?l=1382463474825.png
http://www.sierrachart.com/image.php?l=138246356841.png
[2013-10-22 21:53:34]
1. We get a similar kind of chart for Cotton (CT). The main reason you see chart bars with little volume when using the Continuous Futures Contract chart feature is because there are selected contract months in the Global Symbol Settings which are inactive compared to the others. Determine which ones those are and uncheck them.
2. When using symbols that contain a #, you need to understand how these work. There is nothing we can do about this. Refer to this section here:
https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#Method2
This is all the help we can provide.
Date Time Of Last Edit: 2013-10-22 21:54:25
