Date/Time: Tue, 21 Jan 2025 00:55:07 +0000
[Programming Help] - Please confirm spreadsheet formula
View Count: 784
[2018-06-27 00:07:06]
User68474 - Posts: 201
Is this the proper spreadsheet formula for summing and then averaging all the non-zero numbers, Rows G3:G1418 in Column G of a Spreadsheet Study?
AVERAGE_IGNOREZEROES(G3,G1418)
Furthermore, is the proper place to enter this Formula(or the corrected one): " In one of the available Spreadsheet formula columns, by default K through Z" (pasted from documentation) ?? If so, what cell? (i.e. (X2)?
[2018-07-18 21:17:07]
ForgivingComputers.com - Posts: 987
Yes, that is the correct formula, however it will need an = sign in front of it.
Normally spreadsheet formulas go in row 3 of columns K-Z (or higher if you add more columns in the study inputs), which represents the current bar. Row 4 is the one before that, etc. If you put it in row 3 of one of the columns K-Z, it will copy itself down to the last row, modifying the numbers, so if:
K3: =AVERAGE_IGNOREZEROES(G3,G1418)
K4: =AVERAGE_IGNOREZEROES(G4,G1419)
K5: =AVERAGE_IGNOREZEROES(G5,G1420)
etc.
If you don't want it to do that, then put a $ in front of the row number:
=AVERAGE_IGNOREZEROES(G$3,G$1418)
If only need the formula once, and you don't need one per row, you can use any cell in Column H to hold the formula.
[2018-07-18 22:19:01]
Sawtooth - Posts: 4157
This will give you the average of only 2 cells, G3 and G1418:
This will give you the average of all cells from G3 to G1418 inclusive:
=AVERAGE_IGNOREZEROES(G3:G1418)
[2018-07-18 22:29:27]
Thanks Tom. Missed that part of the description.
Brad
