Date/Time: Mon, 20 Jan 2025 14:04:30 +0000
[Programming Help] - ACSIL Cut Drawing
View Count: 598
[2018-06-26 21:57:41] |
User439067 - Posts: 48 |
I'm using rays to automatically draw lines due to the future time issue where the lines move as new bars get added to the chart. The huge rays really clutter up my chart. Can you cut drawings using ACSIL? Thanks. |
[2018-06-26 22:37:35] |
WarriorTrader - Posts: 245 |
Not sure if you can "cut," but you can delete a ray and draw a line in it's place. --WT |
