Date/Time: Mon, 20 Jan 2025 16:58:32 +0000
improving numbers bars for crypto trading
View Count: 1293
[2018-06-26 18:50:26]
User61576 - Posts: 445
as of now, data from Bitmex is traded in huge numbers (millions+)
this is very problematic to view when using numbers bars or numbers bars calculated studies
it will be great if you could add a divider to the setup of the studies and if it's not 1 (min. value) than the displayed value will be divided by this number.
for example if i will set the divider to be 1M, than the total bitmex volume which is 4118234 will be shown as 4.1 etc.
I will be very happy if you could consider this as this will make life easier for trading crypto with numbers bars data
thanks
[2018-06-27 11:56:30]
This is already supported through this Input:
Numbers Bars: Use Large Volume Number Formatting
[2018-06-27 19:14:50]
i was looking for the same thing but for the "numbers bars calculated values" study and not to the "numbers bars" study
[2018-06-27 19:20:37]
Okay we will see what we can do in regards to that.
[2018-06-28 20:04:57]
John - SC Support - Posts: 37327
There already is the ability to do this with the Numbers Bar Calculated Values study. Simply change the Value Format Option on the Settings page for the study to Large Integer with Suffix.
