Date/Time: Mon, 20 Jan 2025 14:02:57 +0000
Placing orders in trade window
View Count: 823
[2018-06-26 18:42:33] |
User644540 - Posts: 7 |
I want to place a limit order through the chart window, but I cant because the dropdown box with the brackets wont allow me to keep it blank. So everytime I try to place an order its a bracket order.
[2018-06-27 11:41:33] |
You need to disable Use Attached Orders on the Trade Window Main tab.
