Date/Time: Mon, 20 Jan 2025 14:04:36 +0000
1770 - issue with value label Percent Change Since Open Study
View Count: 558
[2018-06-26 08:14:00] |
Acro - Posts: 441 |
Hi Please see attached screenshot. Since I updated to 1770, all my value labels for this study read 0.00% instead of the correct value. The lines drawn are correct, but the value labels are no longer correct |
20180626.png / V - Attached On 2018-06-26 08:13:42 UTC - Size: 11.1 KB - 213 views |
[2018-06-26 19:34:43] |
This has been corrected. The version number has not changed but we have released a new revision of 1770.
