Date/Time: Mon, 20 Jan 2025 13:57:58 +0000
Period OHLC-Var Period-Daily
View Count: 678
[2018-06-26 07:26:37] |
User251131 - Posts: 3 |
For some reason, the Daily Hi/Low (LC are set to ignore) from 2 days is also plotting on my chart even though I have no additional OHLC study on my chart. The 2 extra lines have no texts attached to them. My time period is set to 1. At the moment there are 4 lines, H/L from yesterday with text and H/L from 2 days ago with no text, just 2 lines same colours as for day 1. Thanks |
[2018-06-27 05:52:18] |
We are not really understanding this but we recommend removing all studies from the chart other than the one study you want to use and check for any Chart Drawings on the chart through Tools >> Manage Chart Drawings Window.
