Date/Time: Mon, 20 Jan 2025 13:52:17 +0000
[User Discussion] - Zig Zag Display 2 Different Volume types
View Count: 588
[2018-06-26 04:15:10] |
User106180 - Posts: 88 |
With the Zig Zag study would it be possible to add the ability to display two different volumes types via text labels? At the moment it is only possible to display the specific 'Volume To Accumulate' that is selected. I can do this by duplicating the study and having different 'Text Label Offset' for the difference volume types (ie 'Total Volume' and 'Ask Bid Volume Difference'), but it would be handy to have it in the one study. Thanks |
[2018-06-27 12:01:05] |
We would not consider this at all. This is something that is fully within the control for users to do themselves by modifying the study themselves.: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
