Date/Time: Mon, 20 Jan 2025 17:02:16 +0000
[Programming Help] - Numbers Bars Calculated Values - Create Candlestick of the Ask Volume/Bid Volume
View Count: 1103
[2018-06-26 02:49:44]
User796776 - Posts: 95
Is there a study which would create a candlestick of the range of the Ask Volume/Bid Volume using Numbers Bars Calculated Values?
Specifically the candle would use the Numbers Bars Calculated Values:
Open - 0
High - Maximum Ask Volume Bid Volume Difference
Low - Minimum Ask Volume Bid Volume Difference
Close - Ask Volume Bid Volume Difference
[2018-06-27 21:20:39]
I am using the "Spreadsheet Formula (Bar)" study to solve this.
Settings:
Open Formula : 0
High Formula : (NBCV).SG28
Low Formula : (NBCV).SG29
Close Formula : (NBCC).SG1
There is no Draw Zeros input like the Spreadsheet Study has so the candlestick is not properly drawn.
Is there a way to set the Draw Zeros input on the Spreadsheet Formula (Bar) study?
Date Time Of Last Edit: 2018-06-27 21:21:02
[2018-06-28 10:51:46]
User16876 - Posts: 11
Why don't you use "Ask/Bid Volume Difference Bars" study that makes completely the same I guess...?
