Date/Time: Mon, 20 Jan 2025 16:57:17 +0000
Dom graph bid and ask lines
View Count: 1149
[2018-06-25 17:00:33]
User174262 - Posts: 13
i use the Service Package 5 and level2 for Eurex (data).
The study, market depth historical graph works perfect.
But when I use the dom graph, I only see one ask and bid line. I can not see the full market depth.
I followed the instructions dom graph but unfortunately without success?
Furthermore, I do not understand that in simultaneous trading the dom graph, bid-ask lines are above or below the normal bid and ask lines.
At normal exchange time, this does not work that way.
I see one bid and ask line without fluctuations above or below the market price?
For your reply many thanks
[2018-06-25 19:21:21]
Your account is enabled for EUREX with market depth data.
Go to the chart you want to have market depth data for and open the market depth window with File >> Open Market Depth Window:
File Menu: Open Market Depth Window (File)
After that select Edit >> Screen Images >> Upload Chart with Overlays.
Then paste the link here.
Date Time Of Last Edit: 2018-06-25 19:21:45
[2018-06-25 19:38:12]
http://www.sierrachart.com/image.php?Image=1529955231653.png
[2018-06-26 08:35:33]
Make sure Global Settings >> Data/Trade Service Settings >> Maximum Market Depth Levels is set to 0.
Although the version you are running may not have that setting. To update follow these instructions here:
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2018-06-26 08:35:52
[2018-06-26 20:30:39]
i hope that`s MessageLog help you.
Unfortunately there is no selection point after the Fast update.
("Global Settings >> Data / Trade Service Settings >> Maximum Market Depth Levels is set to 0.")
Software version: 1727 32-bit | 2018-06-26 22:21:05
Usage end date: 2018-07-20 | 2018-06-26 22:21:05
Enabled for: Advanced Features. | 2018-06-26 22:21:05
Enabled for: Advanced Features 2. | 2018-06-26 22:21:05
Enabled for: Sierra Chart Historical Data Service. | 2018-06-26 22:21:05
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-06-26 22:21:05
Enabled for: INDEXES_DATA_BARCHART | 2018-06-26 22:21:05
Enabled for: Eurex with Market Depth | 2018-06-26 22:21:05
Received 1 data feed usernames. | 2018-06-26 22:21:05
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-06-26 22:21:05
Current selected Data/Trading service: DTC - Sub Instance | 2018-06-26 22:21:05
Chart Update Interval: 10 | 2018-06-26 22:21:05
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2018-06-26 22:21:05
2018-06-26 22:21:04 Local computer time | 2018-06-26 22:21:05
2018-06-26 20:21:04 Local computer time in UTC | 2018-06-26 22:21:05
2018-06-26 22:21:04 Local computer time in SC Time Zone | 2018-06-26 22:21:05
2018-06-26 20:19:54 Server time in UTC | 2018-06-26 22:21:05
Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-06-26 22:21:05
Program path: C:\SierraChart\SierraChartInstance_2\ | 2018-06-26 22:21:05
Data Files path: C:\SierraChart\SierraChartInstance_2\Data\ | 2018-06-26 22:21:05
OS Version Number: 6.0 | 2018-06-26 22:21:05
Locale Setting: C | 2018-06-26 22:21:05
[2018-06-28 18:50:58]
i have the current version installed (see below the message log).
Unfortunately, the market depth function does not work. I only see one line bid and ask (dom graph on chart) ???
The ("Global Settings >> Data / Trade Service Settings >> Maximum Market Depth Levels is set to 0.") Thats also okay.
So I hope you can help me to see the complete Market Depth Levels.
Many thanks in advance.
Software version: 1768 64-bit | 2018-06-28 20:34:56
Usage end date: 2018-07-20 | 2018-06-28 20:34:56
Enabled for: Advanced Features. | 2018-06-28 20:34:56
Enabled for: Advanced Features 2. | 2018-06-28 20:34:56
Enabled for: Sierra Chart Historical Data Service. | 2018-06-28 20:34:56
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-06-28 20:34:56
Enabled for: INDEXES_DATA_BARCHART | 2018-06-28 20:34:56
Enabled for: Eurex with Market Depth | 2018-06-28 20:34:56
Received 1 data feed usernames. | 2018-06-28 20:34:56
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-06-28 20:34:56
Current selected Data/Trading service: SC Data - All Services | 2018-06-28 20:34:56
Chart Update Interval: 10 | 2018-06-28 20:34:56
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2018-06-28 20:34:56
2018-06-28 20:34:56 Local computer time | 2018-06-28 20:34:56
2018-06-28 18:34:56 Local computer time in UTC | 2018-06-28 20:34:56
2018-06-28 20:34:56 Local computer time in SC Time Zone | 2018-06-28 20:34:56
2018-06-28 18:25:37 Server time in UTC | 2018-06-28 20:34:56
Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-06-28 20:34:56
Program path: C:\SierraChart\ | 2018-06-28 20:34:56
Data Files path: C:\SierraChart\Data\ | 2018-06-28 20:34:56
OS Version Number: 6.0 | 2018-06-28 20:34:56
Locale Setting: C | 2018-06-28 20:34:56
File >> Disconnect selected. | 2018-06-28 20:35:27
DTC Client socket (17) | Initiating close of socket by core. | 2018-06-28 20:35:27
DTC Client socket (17) | Shutdown started. Waiting for graceful close. | 2018-06-28 20:35:27
SC Data - All Services | Disconnected from the server. | 2018-06-28 20:35:27
SC Data - All Services | Disconnected. | 2018-06-28 20:35:27
DTC Client socket (17) | Socket gracefully closed by remote side. | 2018-06-28 20:35:28
DTC Client socket (17) | Closed. | 2018-06-28 20:35:28
SC Data - All Services | Connected to data server. | 2018-06-28 20:35:31
Notice: Not connected to Live trading account to receive CME real-time futures data at lower cost exchange fee. | 2018-06-28 20:35:31
SC Data - All Services | Starting real-time market data updates for: CLH18. ID: 1 | 2018-06-28 20:35:31
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: CLH18 | 2018-06-28 20:35:31
SC Data - All Services | Requesting security definition data for: CLH18. ID: 1 | 2018-06-28 20:35:31
Intraday data recording state for symbol CLH18 is set to download 'Pending'. | 2018-06-28 20:35:31
Delaying start of download for CLH18 | 2018-06-28 20:35:31
SC Data - All Services | Starting real-time market data updates for: A6H18. ID: 2 | 2018-06-28 20:35:31
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: A6H18 | 2018-06-28 20:35:31
SC Data - All Services | Requesting security definition data for: A6H18. ID: 2 | 2018-06-28 20:35:31
Intraday data recording state for symbol A6H18 is set to download 'Pending'. | 2018-06-28 20:35:31
Mapping DYU18 to DYU18. Service code: eurex | 2018-06-28 20:35:31
SC Data - All Services | Starting real-time market data updates for: DYU18. ID: 3 | 2018-06-28 20:35:31
SC Data - All Services | Using username 0 | 2018-06-28 20:35:31
SC Data - All Services | Using low bandwidth mode. | 2018-06-28 20:35:31
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 443 | 2018-06-28 20:35:31
SC Data - All Services | Requesting security definition data for: DYU18. ID: 3 | 2018-06-28 20:35:31
Requesting market depth updates for: DYU18 if supported. | 2018-06-28 20:35:31
Intraday data recording state for symbol DYU18 is set to download 'Pending'. | 2018-06-28 20:35:31
DTC Client socket (25) | Creating socket. | 2018-06-28 20:35:31
DTC Client socket (25) | Connecting to IP: 8.18.161.135. | 2018-06-28 20:35:31
Mapping GGU18 to GGU18. Service code: eurex | 2018-06-28 20:35:31
SC Data - All Services | Starting real-time market data updates for: GGU18. ID: 4 | 2018-06-28 20:35:31
SC Data - All Services | Requesting security definition data for: GGU18. ID: 4 | 2018-06-28 20:35:31
Requesting market depth updates for: GGU18 if supported. | 2018-06-28 20:35:31
Intraday data recording state for symbol GGU18 is set to download 'Pending'. | 2018-06-28 20:35:31
SC Data - All Services | Connected to server. | 2018-06-28 20:35:31
SC Data - All Services | Starting socket receive thread. | 2018-06-28 20:35:31
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-28 20:35:31
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-28 20:35:31
SC Data - All Services | Sending logon request message. | 2018-06-28 20:35:31
SC Data - All Services | Received logon response. | 2018-06-28 20:35:31
SC Data - All Services | Server Name: SC Realtime Server. | 2018-06-28 20:35:31
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-28 20:35:31
SC Data - All Services | Successfully connected. | 2018-06-28 20:35:31
SC Data - All Services | Trading is not supported. | 2018-06-28 20:35:31
SC Data - All Services | Restarting real-time data updates for symbol: DYU18 -> DYU18 | 2018-06-28 20:35:31
SC Data - All Services | Restarting real-time data updates for symbol: GGU18 -> GGU18 | 2018-06-28 20:35:31
SC Data - All Services | Received security definition for symbol DYU18 | 2018-06-28 20:35:31
SC Data - All Services | Market Depth data has been rejected for symbol: DYU18. Low bandwidth option enabled. | 2018-06-28 20:35:31
SC Data - All Services | Received security definition for symbol GGU18 | 2018-06-28 20:35:31
SC Data - All Services | Market Depth data has been rejected for symbol: GGU18. Low bandwidth option enabled. | 2018-06-28 20:35:31
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\GGU18.2018-06-28.depth | 2018-06-28 20:35:32
Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\DYU18.2018-06-28.depth | 2018-06-28 20:35:34
HD Request # 10 | Downloading Intraday chart data for CLH18 to the file CLH18.scid. Service: nymex | 2018-06-28 20:35:35
HD Request # 10 | Download start date-time: 2018-02-20 20:29:49.000 | 2018-06-28 20:35:35
HD Request # 10 | Using server: ds7.sierracharts.com port 10149 | 2018-06-28 20:35:35
Socket (26) | Creating socket. | 2018-06-28 20:35:35
Socket (26) | Connecting to IP: 8.18.161.133. | 2018-06-28 20:35:35
HD Request # 10 | Setting DTC encoding to Binary VLS | 2018-06-28 20:35:35
HD Request # 10 | Sending historical data logon request message. | 2018-06-28 20:35:35
HD Request # 10 | Requesting Intraday data. Start date-time: 2018-02-20 20:29:49. Record interval: 0. Symbol: CLH18 | 2018-06-28 20:35:36
HD Request # 10 | Decompressing data. | 2018-06-28 20:35:36
HD Request # 10 | Receiving Intraday data for CLH18 starting at 2018-02-20 20:29:49 | 2018-06-28 20:35:36
Socket (26) | Initiating close of socket by core. | 2018-06-28 20:35:36
Socket (26) | Shutdown started. Waiting for graceful close. | 2018-06-28 20:35:36
Historical data download thread signaled to stop. | 2018-06-28 20:35:36
HD Request # 10 | Received 1 record from 2018-02-20 20:29:49 to 2018-02-20 20:29:49 (0.0 seconds) and wrote 0 records for CLH18 | 2018-06-28 20:35:36
HD Request # 10 | Completion time: 0s | 2018-06-28 20:35:36
HD Request # 10 | Intraday data download complete for CLH18. Unique request ID: 9 | 2018-06-28 20:35:36
Removed historical data download ID 9 | 2018-06-28 20:35:36
Real-time Intraday chart data file updates started for CLH18 | 2018-06-28 20:35:36
Intraday chart data file opened for CLH18 | 2018-06-28 20:35:36
HD Request # 11 | Downloading Intraday chart data for A6H18 to the file A6H18.scid. Service: cme | 2018-06-28 20:35:36
HD Request # 11 | Download start date-time: 2018-03-19 15:06:12.000 | 2018-06-28 20:35:36
HD Request # 11 | Using server: ds1.sierracharts.com port 10150 | 2018-06-28 20:35:36
Socket (27) | Creating socket. | 2018-06-28 20:35:36
Socket (27) | Connecting to IP: 8.18.161.135. | 2018-06-28 20:35:36
Socket (26) | Socket gracefully closed by remote side. | 2018-06-28 20:35:36
Socket (26) | Closed. | 2018-06-28 20:35:36
HD Request # 11 | Setting DTC encoding to Binary VLS | 2018-06-28 20:35:36
HD Request # 11 | Sending historical data logon request message. | 2018-06-28 20:35:36
HD Request # 11 | Requesting Intraday data. Start date-time: 2018-03-19 15:06:12. Record interval: 0. Symbol: 6AH18 | 2018-06-28 20:35:36
HD Request # 11 | Decompressing data. | 2018-06-28 20:35:36
HD Request # 11 | Receiving Intraday data for A6H18 starting at 2018-03-19 15:06:12 | 2018-06-28 20:35:36
Socket (27) | Initiating close of socket by core. | 2018-06-28 20:35:36
Socket (27) | Shutdown started. Waiting for graceful close. | 2018-06-28 20:35:36
HD Request # 11 | Received 1 record from 2018-03-19 15:06:12 to 2018-03-19 15:06:12 (0.0 seconds) and wrote 0 records for A6H18 | 2018-06-28 20:35:36
HD Request # 11 | Completion time: 1s | 2018-06-28 20:35:36
HD Request # 11 | Intraday data download complete for A6H18. Unique request ID: 10 | 2018-06-28 20:35:36
Removed historical data download ID 10 | 2018-06-28 20:35:36
Real-time Intraday chart data file updates started for A6H18 | 2018-06-28 20:35:36
Intraday chart data file opened for A6H18 | 2018-06-28 20:35:36
HD Request # 12 | Downloading Intraday chart data for DYU18 to the file DYU18.scid. Service: eurex | 2018-06-28 20:35:36
HD Request # 12 | Download start date-time: 2018-06-28 20:35:24.000 | 2018-06-28 20:35:36
HD Request # 12 | Using server: ds7.sierracharts.com port 10149 | 2018-06-28 20:35:36
Socket (28) | Creating socket. | 2018-06-28 20:35:36
Socket (28) | Connecting to IP: 8.18.161.133. | 2018-06-28 20:35:36
Socket (27) | Socket gracefully closed by remote side. | 2018-06-28 20:35:36
Socket (27) | Closed. | 2018-06-28 20:35:36
HD Request # 12 | Setting DTC encoding to Binary VLS | 2018-06-28 20:35:36
HD Request # 12 | Sending historical data logon request message. | 2018-06-28 20:35:36
HD Request # 12 | Requesting Intraday data. Start date-time: 2018-06-28 20:35:24. Record interval: 0. Symbol: DYU18 | 2018-06-28 20:35:37
HD Request # 12 | Decompressing data. | 2018-06-28 20:35:37
HD Request # 12 | Receiving Intraday data for DYU18 starting at 2018-06-28 20:35:24 | 2018-06-28 20:35:37
Socket (28) | Initiating close of socket by core. | 2018-06-28 20:35:37
Socket (28) | Shutdown started. Waiting for graceful close. | 2018-06-28 20:35:37
Historical data download thread signaled to stop. | 2018-06-28 20:35:37
HD Request # 12 | Received 2 records from 2018-06-28 20:35:24 to 2018-06-28 20:35:24 (0.0 seconds) and wrote 0 records for DYU18 | 2018-06-28 20:35:37
HD Request # 12 | Timestamp of first Intraday data file record written: 2018-06-28 20:35:34 | 2018-06-28 20:35:37
Added 1 Time and Sales records to Intraday data file for DYU18 after download. | 2018-06-28 20:35:37
HD Request # 12 | Completion time: 0s | 2018-06-28 20:35:37
HD Request # 12 | Intraday data download complete for DYU18. Unique request ID: 11 | 2018-06-28 20:35:37
Removed historical data download ID 11 | 2018-06-28 20:35:37
Real-time Intraday chart data file updates started for DYU18 | 2018-06-28 20:35:37
Intraday chart data file opened for DYU18 | 2018-06-28 20:35:37
HD Request # 13 | Downloading Intraday chart data for GGU18 to the file GGU18.scid. Service: eurex | 2018-06-28 20:35:37
HD Request # 13 | Download start date-time: 2018-06-28 20:35:11.000 | 2018-06-28 20:35:37
HD Request # 13 | Using server: ds1.sierracharts.com port 10150 | 2018-06-28 20:35:37
Socket (29) | Creating socket. | 2018-06-28 20:35:37
Socket (29) | Connecting to IP: 8.18.161.135. | 2018-06-28 20:35:37
Socket (28) | Received socket Close event. | 2018-06-28 20:35:37
Socket (28) | Still waiting for graceful close or receive error. | 2018-06-28 20:35:37
Socket (28) | Socket gracefully closed by remote side. | 2018-06-28 20:35:37
Socket (28) | Closed. | 2018-06-28 20:35:37
HD Request # 13 | Setting DTC encoding to Binary VLS | 2018-06-28 20:35:37
HD Request # 13 | Sending historical data logon request message. | 2018-06-28 20:35:37
HD Request # 13 | Requesting Intraday data. Start date-time: 2018-06-28 20:35:11. Record interval: 0. Symbol: GGU18 | 2018-06-28 20:35:37
HD Request # 13 | Decompressing data. | 2018-06-28 20:35:37
HD Request # 13 | Receiving Intraday data for GGU18 starting at 2018-06-28 20:35:11 | 2018-06-28 20:35:37
HD Request # 13 | Timestamp of first Intraday data file record written: 2018-06-28 20:35:34 | 2018-06-28 20:35:37
Socket (29) | Initiating close of socket by core. | 2018-06-28 20:35:37
Socket (29) | Shutdown started. Waiting for graceful close. | 2018-06-28 20:35:37
HD Request # 13 | Received 17 records from 2018-06-28 20:35:11 to 2018-06-28 20:35:34 (23.0 seconds) and wrote 1 record for GGU18 | 2018-06-28 20:35:37
HD Request # 13 | Completion time: 0s | 2018-06-28 20:35:37
HD Request # 13 | Intraday data download complete for GGU18. Unique request ID: 12 | 2018-06-28 20:35:37
Removed historical data download ID 12 | 2018-06-28 20:35:37
Real-time Intraday chart data file updates started for GGU18 | 2018-06-28 20:35:37
Intraday chart data file opened for GGU18 | 2018-06-28 20:35:37
Socket (29) | Socket gracefully closed by remote side. | 2018-06-28 20:35:37
Socket (29) | Closed. | 2018-06-28 20:35:37
Opened cached Intraday file: C:\SierraChart\Data\DYU18.scid | 2018-06-28 20:35:39
Opened cached Intraday file: C:\SierraChart\Data\GGU18.scid | 2018-06-28 20:35:45
[2018-06-28 18:52:46]
[2018-06-28 19:26:19]
This is the problem:
You need to disable this option:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#LowBandwidthOption
[2018-06-28 19:39:36]
Okay many thanks it works
