Date/Time: Mon, 20 Jan 2025 13:55:29 +0000
Set ratio for multiple targets using Attached Orders with variable entry quantities
View Count: 785
[2018-06-25 15:36:44]
mosheikh - Posts: 5
When using Attached Orders, is there any way to maintain a set ratio between the attached target orders when quantity is changed? Currently when I try to adjust the quantity of my entry order, my target exits (2 orders) are split evenly, when the initial setting was an 80/20 split for the orders.
For example, I use a 5 quantity entry order, and set my targets to have quantities of 4 and 1. When I change my order quantity to 10 however, the targets reset to quantities of 5 each. Is there any way to ensure a change of quantity to 10 would result in exit targets of quantities 8 and 2 to maintain the initial ratio set?
Thank you.
[2018-06-25 22:25:54]
Yes but this is done indirectly by using preset Trade Window Configurations as explained here:
Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations
So you have to save your trade window configurations with each one set to the quantity that you want and then choose among those.
