Date/Time: Mon, 20 Jan 2025 14:00:22 +0000
QG Mini Nat Gas Symbol Settings Incorrect? - CTS
View Count: 710
[2018-06-22 19:18:04]
User948528 - Posts: 108
Are the server symbol settings in display format and tick size for QG mini nat gas correct? They appear to be different than the CME quotes and to the full size nat gas.
Also when one clicks update symbol settings from server, does this overwrite settings like commissions which are saved per contract?
[2018-06-22 21:08:48]
The Symbol Settings for QG have been updated to match NG.
You need to Update your Symbol Settings following the steps here:
And then you should apply the new settings to your existing QG charts following the documentation here:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
