Date/Time: Mon, 20 Jan 2025 13:50:18 +0000
DVA-POC-Volume Points
View Count: 1962
[2018-06-22 12:05:59]
User251131 - Posts: 3
1) how can i add the developing value area and Value POC to my charts
2) is there a way to add the highest volume level within each candle into my chart-typically this is denoted with a dot
[2018-06-25 18:12:09]
John - SC Support - Posts: 37327
1. You can use the Volume by Price study and if you just want to see the Value Area and POC lines, then set the Input for Draw Mode to POC, VAH, VAL, VWAP Lines Only. Refer to the documentation here on this option:
Volume By Price Study: Draw Mode
2. There is not a way to mark the highest volume level relative to standard candles. The best way to see this is to use the Numbers Bars study and set the Input Highlight Maximum Value In to the column of data you want to see the highlight for. You will find the documentation for this here:
Numbers Bars: Highlight Maximum Value In
We are also looking at another possible way to mark on this with the Candle displays. If we are able to get this done easily, we will let you know in this post.
