Date/Time: Mon, 20 Jan 2025 14:04:52 +0000
Order Fills Markers Only
View Count: 1390
[2018-06-21 22:22:08] |
User311951 - Posts: 31 |
Hi, I like to have the 'Show Order Fills' option enabled to see where I have entered and exited trades. However I only want to see the markers (i.e. the triangles) and I do not want to see the price label as this takes up too much space. Is there a way to remove the label and only see the Order Fills with the triangle? Thanks, Talai |
[2018-06-22 14:34:00] |
Yes of course. Complete documentation for this is here: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-22 14:34:21] |
Refer to the following documentation, particularly step 9 which goes over turning on/off the options for Order Fills: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
