Date/Time: Mon, 20 Jan 2025 13:52:56 +0000
max loss per trade
View Count: 921
[2018-06-21 16:12:59] |
Cavalry3162 - Posts: 523 |
Hello SC, is there a way to set a max loss on a per trade level? thank you, Andreas |
[2018-06-21 18:09:38] |
Only through the use of Attached Orders: http://www.sierrachart.com/index.php?page=doc/AttachedOrders.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-21 18:18:30] |
yeah, i was aware of that.. thank you, though.. i was looking for a way to prevent me from (re)moving that stop loss order.. or at least prevent me from screwing up too much... the daily loss limit is great but i would love to have it on a per trade basis.. thanks though, Andreas |
