Date/Time: Mon, 20 Jan 2025 14:00:22 +0000
[User Discussion] - Volume By Price Bars - Ability to have open/close of bars displayed
View Count: 753
[2018-06-21 14:41:53]
JKTT - Posts: 7
Hi Team,
Currently we're unable to get the open/close to display on the Volume Profile bars, we can do this in Numbers bars but not for the VP bars.
Can you please advise a way to achieve this?
I am currently using the numbers bars on top of my VP bars with the prints made tiny so as not to mess up the chart, but this isn't ideal.
image11.png / V - Attached On 2018-06-21 14:41:30 UTC - Size: 133.79 KB - 278 views
[2018-06-24 08:47:22]
@sstfrederik - Posts: 405
Browsing through the forum and see if I can help some SC users.
You will not get a SC response to a user discussion post.
You can use this study:
https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=54&Name=Highest_High_Lowest_Low_Over_N_Bars
Set it to 1 bar, use open and last for the input data, and use a subgraph drawing of your choosing to highlight the open and close price levels of each bar.
Kind regards,
Frederik (at simplesystemtrading dot com)
