Date/Time: Mon, 20 Jan 2025 13:54:18 +0000
Lost Control Bar 8
View Count: 666
[2018-06-21 13:17:12]
User92573 - Posts: 541
Dear Support
On moving Sierra3.cfg from one machine to another I am losing control bar 8.
I have selected and deselected it multiple times via Window>>Control Bars but it is still not visible.
Is there a way to recover Control Bar 8 other than setting it up again?
Note: I can lock it to the top before copying - then it appears correctly when I open SC on the other machine. I can also pin to the left, right, or bottom but as soon as I select float it vanishes.
Many thanks
Date Time Of Last Edit: 2018-06-21 13:36:57
[2018-06-21 13:53:41]
Select Window >> Reset Windows.
[2018-06-21 19:38:46]
Thank you for the prompt reply.
I have not tried the solution as I solved the issue as follows before checking the support board.
1) Reduce the Size of SC when open on a single monitor.
2) Close and copy Sierra3.cfg file to the other PC.
3) Open SC which now has Control Bar 8 displayed.
4) Resize SC and Control Bar 8.
I am now saving a Backup Sierra3.cfg for both machines independently.
Thank you.
