Date/Time: Sun, 20 Sep 2026 10:00:26 +0000
[Programming Help] - trouble Setting up Alerts
View Count: 1548
| [2018-06-20 21:24:22] |
| User298180 - Posts: 7 |
Hi I am trying to set up simple price alerts, the first one being when price crosses over the VWAP to get the colour of the bar to change, please see the attached picture that shows it is sometimes working but not always, also I have tried using the crossover function to create alerts but it doesn't seem to be working? thanks
| Attachment Deleted. |
| [2018-06-20 22:17:54] |
| Xfanman1 - Posts: 320 |
Your formula is saying you want to color the bar only when C(Closing Price) is equal to VWAP. You want to capture if the bar crosses over VWAP so try this: =OR(CROSSFROMABOVE(ID1.SG1,C),CROSSFROMBELOW(ID1.SG1,C)) This should color your bar if the bar crosses and Closes from below OR crosses and Closes from above VWAP. It will not capture wicks that touch your VWAP but don't cross between the Open and Close body of the candle. -- Scott Date Time Of Last Edit: 2018-06-20 22:23:09
| [2018-06-20 22:27:03] |
Hi Scott, thanks for the quick response, I have just tried your code and it works a lot better, but is there a way where you can get it to trigger on wicks that just touch of a level as well? thanks dan
| [2018-06-20 23:02:49] |
Using the L or H of the candle produced inconsistent results for me when testing for you. I would think there is another way to capture the wick movement too but it's beyond my limited knowledge at the moment. Maybe the Engineering team or another more skilled user will chime in and we'll both learn something. -- Scott |
