Date/Time: Mon, 20 Jan 2025 13:49:22 +0000
using numbers bars calculated with bitcoin volume
View Count: 879
[2018-06-20 19:39:03] |
User61576 - Posts: 445 |
in the past this issue raised and SC support indicated numbers bars info can not be working with Bitcoin any update? thanks! |
[2018-06-21 04:35:37] |
This should not be a problem when using BitMex symbols: http://www.sierrachart.com/index.php?page=doc/CryptocurrencyDataServices.php There could be a display issue with symbols using fractional quantities. But this is not anything that we will make any effort to support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-21 04:35:51
