Date/Time: Mon, 20 Jan 2025 13:52:12 +0000
[Programming Help] - MA hull crossover
View Count: 685
[2018-06-21 07:46:19]
User494206 - Posts: 44
I want MA hull crossover arrows in my chart. How can I do that?
[2018-06-24 08:35:40]
@sstfrederik - Posts: 405
Browsing through the forum and see if I can help some SC users.
You can do this with loading separate Hull MA studies and use the Colorbar based on alert condition study to formulate your arrows.
Use the attached chartbook. You will likely need to change the symbol on the chart.
Kind regards,
Frederik (at simplesystemtrading dot com)
attachmentChartbook28.Cht - Attached On 2018-06-24 08:34:30 UTC - Size: 57.81 KB - 377 views
