Date/Time: Mon, 20 Jan 2025 13:58:19 +0000
Rithmic Hystorical data problem
View Count: 695
[2018-06-20 11:09:53] |
User00111 - Posts: 111 |
Just now I set Sierra with Rithmic data, but I have a problem to download Historical data. Attached daily chart with the Setting setup. If I set in Advanced Setting / Continuous Contract: Continous Futures Contract - Volume based rollover, Back Adjustment /// The data is very limited If I set in Advanced Setting / Continuous Contract: NONE /// The historical data are few how can I resolve, taking into account that I have deleted and redone data download -- Antonio |
ES_AdS_Coninuos....png / V - Attached On 2018-06-20 11:09:34 UTC - Size: 241.37 KB - 260 views ES_AdS_None.png / V - Attached On 2018-06-20 11:09:41 UTC - Size: 344.21 KB - 287 views |
[2018-06-21 05:17:05] |
You need to follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data And re-download data for all contract months in the list. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
