Date/Time: Mon, 20 Jan 2025 13:53:37 +0000
TPO Time
View Count: 633
[2018-06-20 09:56:37] |
RIFT - Posts: 124 |
Can you please add the TPO time to the time scale, see the lower part of screenshot? I do not see what block was when. Thank you very much! |
Attachment Deleted. |
[2018-06-21 10:04:46] |
Yes we will do this assuming there are no complications.
[2018-06-25 09:55:17] |
This is in version 1769.
