Date/Time: Mon, 20 Jan 2025 13:53:07 +0000
Version 1767 Larg Volume Trade Study Bug
View Count: 737
[2018-06-20 09:41:39] |
RIFT - Posts: 124 |
Large Volme Trade Study darkens the background, see the screenshot... left is without study, right is with study |
[2018-06-20 11:45:46] |
We are looking into this. For now in the Input settings for the study set Use Transparent Draw Style to No.
[2018-06-20 12:24:22] |
This is now resolved. Update Sierra Chart again with Help >> Download Current Version.
[2018-06-20 13:03:05] |
Alberto Gauer - Posts: 121 |
Didn´t want to open a new thread for the same study, it´s more of a request if possible. Can you add the option to set the level of transparency of this study, in a future release? Thanks |
[2018-06-21 05:35:30] |
This is already supported. Refer to the documentation here: Large Volume Trade Indicator: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-21 05:35:43] |
The level of transparency is controllable. Refer to the following: Chart Studies: Subgraphs Tab >> Transparency Level for Fill Styles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
