Date/Time: Mon, 20 Jan 2025 14:04:42 +0000
Bug in releases after 1764 / Large Volume Trade Indicator
View Count: 1154
[2018-06-19 22:19:25] |
nosast2 - Posts: 73 |
Please see images attached. The Large Volume Trade Indicator shows way to many prints all over the place in release 1765 to 1767. I went back to 1764 which seems to be the last version without the bug. Could you please have a look into that? |
Attachment Deleted. |
[2018-06-20 04:17:22] |
Okay we will look into this. But allow one to two days.
[2018-06-20 07:05:48] |
We cannot reproduce this. Provide this particular chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-20 07:59:02] |
User106180 - Posts: 88 |
I am having a similar problem. Here is a chart showing the problem below. Thanks http://www.sierrachart.com/image.php?Image=1529481505391.png |
[2018-06-20 10:25:49] |
Please find attached the chartbook with the error.
Date Time Of Last Edit: 2018-06-20 10:26:09
Chartbook1_Support.Cht - Attached On 2018-06-20 10:26:03 UTC - Size: 95.09 KB - 313 views |
[2018-06-20 11:45:59] |
We are looking into this. For now in the Input settings for the study set Use Transparent Draw Style to No.
[2018-06-20 12:29:43] |
This is now resolved. Update Sierra Chart again with Help >> Download Current Version.
[2018-06-20 16:30:57] |
I can confirm, it's fixed! Thx |
