Date/Time: Mon, 20 Jan 2025 13:46:42 +0000
Inquiries
View Count: 681
[2018-06-19 01:25:46] |
User157806 - Posts: 71 |
Few questions. 1. Is it possible to download the historical replay data locally onto the computer so we can connect to it offline and replay data? 2. What folder within the sierra charts directory on the hard drive will contain all the settings for global settings within the platform? For example I want to be able to migrate all the global setting changes I made on one sierra charts to another computer? |
[2018-06-19 05:28:07] |
1. This is automatically the case. There is nothing special to do. Just make sure that when connected to the data feed, you are viewing the chart that you want to later replay. 2. This is explained here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-19 05:29:00
[2018-06-25 22:52:42] |
Thanks for the answer just to confirm for question #1 does the CQG fix connection have to be connected to establish market replay?
[2018-06-26 07:49:12] |
No, a connection is definitely not required for a replay.
