Date/Time: Mon, 20 Jan 2025 13:50:27 +0000
Problem logging into chart
View Count: 717
[2018-06-18 16:05:44]
User944448 - Posts: 2
I have been using my Sierra chart for several weeks and today when I try to log into the chart the log says "incorrect username or password" I have double checked and still getting the message. Please advise
[2018-06-18 16:24:31]
Refer to:
CQG Trading Platform Service: Common Error Messages
[2018-06-18 16:53:37]
Checked and everything is correct. Still unable to connect.
Reading Internal Order ID file. | 2018-06-18 09:31:27
Reading Trade Orders file. | 2018-06-18 09:31:28
Reading Trade Positions file. | 2018-06-18 09:31:28
Listening on UDP port 22904. | 2018-06-18 09:31:28
Software version: 1750 64-bit | 2018-06-18 09:31:28
Usage end date: 2018-07-13 | 2018-06-18 09:31:28
Enabled for: Advanced Features. | 2018-06-18 09:31:28
Enabled for: Sierra Chart Historical Data Service. | 2018-06-18 09:31:28
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-06-18 09:31:28
Current selected Data/Trading service: CQG WebAPI | 2018-06-18 09:31:28
Chart Update Interval: 500 | 2018-06-18 09:31:28
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-06-18 09:31:28
2018-06-18 09:31:27 Local computer time | 2018-06-18 09:31:28
2018-06-18 16:31:27 Local computer time in UTC | 2018-06-18 09:31:28
2018-06-18 09:31:27 Local computer time in SC Time Zone | 2018-06-18 09:31:28
2018-06-18 16:31:42 Server time in UTC | 2018-06-18 09:31:28
Local computer UTC time and Server UTC time difference: 15 seconds. | 2018-06-18 09:31:28
Program path: C:\SierraChart\ | 2018-06-18 09:31:28
Data Files path: C:\SierraChart\Data\ | 2018-06-18 09:31:28
OS Version Number: 6.1 | 2018-06-18 09:31:28
Locale Setting: C | 2018-06-18 09:31:28
Checking for new symbol settings for service code cqg | 2018-06-18 09:31:28
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-06-18 09:31:28
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-06-18 09:31:28
Symbol settings are up-to-date for cqg | 2018-06-18 09:31:28
Received 5 login tokens. | 2018-06-18 09:31:28
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-06-18 09:31:30
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-06-18 09:31:30
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-06-18 09:31:33
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-06-18 09:31:33
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-06-18 09:31:33
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-18 09:31:33
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-06-18 09:31:33
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-06-18 09:31:33
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-06-18 09:31:33
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-18 09:31:33
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-06-18 09:31:33
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-06-18 09:31:35
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-06-18 09:31:35
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-18 09:31:35
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-06-18 09:31:35
CQG WebAPI | Connecting to server demoapi.cqg.com | 2018-06-18 09:31:38
CQG WebSocket | Connecting to WebSocket server. | 2018-06-18 09:31:38
CQG WebSocket socket (6) | Creating socket. Using TLS 1.2. | 2018-06-18 09:31:38
CQG WebSocket socket (6) | Connecting to IP: 208.48.16.32. | 2018-06-18 09:31:38
CQG WebSocket | Opening WebSocket. | 2018-06-18 09:31:38
CQG WebSocket | Sending WebSocket handshake. | 2018-06-18 09:31:38
CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-06-18 09:31:38
CQG WebSocket | Header line. Connection: upgrade | 2018-06-18 09:31:38
CQG WebSocket | Header line. Sec-WebSocket-Accept: 5K+3socbD+MmqIAWcdKpMExFEl0= | 2018-06-18 09:31:38
CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-06-18 09:31:38
CQG WebSocket | Header line. Upgrade: websocket | 2018-06-18 09:31:38
CQG WebSocket | Header line. | 2018-06-18 09:31:38
CQG WebSocket | Web socket state is now open. | 2018-06-18 09:31:38
CQG WebAPI | WebSocket connected. | 2018-06-18 09:31:38
CQG WebAPI | Sending market data logon message. | 2018-06-18 09:31:38
CQG WebAPI | Market data logon unsuccessful. Server message: Username or password is incorrect. | 2018-06-18 09:31:39 *
CQG WebSocket socket (6) | Adding bytes from final send buffer from buffered socket: 8 | 2018-06-18 09:31:39
CQG WebSocket socket (6) | Initiating close of socket by core. | 2018-06-18 09:31:39
CQG WebSocket | WebSocket closed. | 2018-06-18 09:31:39
CQG WebSocket socket (6) | Sending bytes from final send buffer: 8 | 2018-06-18 09:31:39
CQG WebAPI | WebSocket closed. | 2018-06-18 09:31:39
CQG WebSocket socket (6) | Write in progress. Shutdown being delayed. | 2018-06-18 09:31:39
CQG WebAPI | Disconnected. | 2018-06-18 09:31:39
CQG WebSocket socket (6) | Write has completed. Shutdown being performed. | 2018-06-18 09:31:39
CQG WebSocket socket (6) | Shutdown started. Waiting for graceful close. | 2018-06-18 09:31:39
CQG WebSocket socket (6) | Socket gracefully closed by remote side. | 2018-06-18 09:31:39
CQG WebSocket socket (6) | Closed. | 2018-06-18 09:31:39
CQG WebAPI | Connecting to server demoapi.cqg.com | 2018-06-18 09:34:09
CQG WebSocket | Connecting to WebSocket server. | 2018-06-18 09:34:09
CQG WebSocket socket (9) | Creating socket. Using TLS 1.2. | 2018-06-18 09:34:09
CQG WebSocket socket (9) | Connecting to IP: 208.48.16.32. | 2018-06-18 09:34:09
CQG WebSocket | Opening WebSocket. | 2018-06-18 09:34:09
CQG WebSocket | Sending WebSocket handshake. | 2018-06-18 09:34:09
CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-06-18 09:34:09
CQG WebSocket | Header line. Connection: upgrade | 2018-06-18 09:34:09
CQG WebSocket | Header line. Sec-WebSocket-Accept: TODyCJAtV8WTe9a0sZfVn7TKNPw= | 2018-06-18 09:34:09
CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-06-18 09:34:09
CQG WebSocket | Header line. Upgrade: websocket | 2018-06-18 09:34:09
CQG WebSocket | Header line. | 2018-06-18 09:34:09
CQG WebSocket | Web socket state is now open. | 2018-06-18 09:34:09
CQG WebAPI | WebSocket connected. | 2018-06-18 09:34:09
CQG WebAPI | Sending market data logon message. | 2018-06-18 09:34:09
CQG WebAPI | Market data logon unsuccessful. Server message: Username or password is incorrect. | 2018-06-18 09:34:10 *
CQG WebSocket socket (9) | Adding bytes from final send buffer from buffered socket: 8 | 2018-06-18 09:34:10
CQG WebSocket socket (9) | Initiating close of socket by core. | 2018-06-18 09:34:10
CQG WebSocket | WebSocket closed. | 2018-06-18 09:34:10
CQG WebAPI | WebSocket closed. | 2018-06-18 09:34:10
CQG WebAPI | Disconnected. | 2018-06-18 09:34:10
CQG WebSocket socket (9) | Sending bytes from final send buffer: 8 | 2018-06-18 09:34:10
CQG WebSocket socket (9) | Write in progress. Shutdown being delayed. | 2018-06-18 09:34:10
CQG WebSocket socket (9) | Write has completed. Shutdown being performed. | 2018-06-18 09:34:10
CQG WebSocket socket (9) | Shutdown started. Waiting for graceful close. | 2018-06-18 09:34:10
CQG WebSocket socket (9) | Socket gracefully closed by remote side. | 2018-06-18 09:34:10
CQG WebSocket socket (9) | Closed. | 2018-06-18 09:34:10
CQG WebAPI | Connecting to server demoapi.cqg.com | 2018-06-18 09:41:01
CQG WebSocket | Connecting to WebSocket server. | 2018-06-18 09:41:01
CQG WebSocket socket (17) | Creating socket. Using TLS 1.2. | 2018-06-18 09:41:01
CQG WebSocket socket (17) | Connecting to IP: 208.48.16.32. | 2018-06-18 09:41:01
CQG WebSocket | Opening WebSocket. | 2018-06-18 09:41:01
CQG WebSocket | Sending WebSocket handshake. | 2018-06-18 09:41:01
CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-06-18 09:41:01
CQG WebSocket | Header line. Connection: upgrade | 2018-06-18 09:41:01
CQG WebSocket | Header line. Sec-WebSocket-Accept: uUpXjjscq4tRrzM4YZMHv2IPY/4= | 2018-06-18 09:41:01
CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-06-18 09:41:01
CQG WebSocket | Header line. Upgrade: websocket | 2018-06-18 09:41:01
CQG WebSocket | Header line. | 2018-06-18 09:41:01
CQG WebSocket | Web socket state is now open. | 2018-06-18 09:41:01
CQG WebAPI | WebSocket connected. | 2018-06-18 09:41:01
CQG WebAPI | Sending market data logon message. | 2018-06-18 09:41:01
CQG WebAPI | Market data logon unsuccessful. Server message: Username or password is incorrect. | 2018-06-18 09:41:01 *
CQG WebSocket socket (17) | Adding bytes from final send buffer from buffered socket: 8 | 2018-06-18 09:41:01
CQG WebSocket socket (17) | Initiating close of socket by core. | 2018-06-18 09:41:01
CQG WebSocket | WebSocket closed. | 2018-06-18 09:41:01
CQG WebAPI | WebSocket closed. | 2018-06-18 09:41:01
CQG WebAPI | Disconnected. | 2018-06-18 09:41:01
CQG WebSocket socket (17) | Sending bytes from final send buffer: 8 | 2018-06-18 09:41:01
CQG WebSocket socket (17) | Write in progress. Shutdown being delayed. | 2018-06-18 09:41:01
CQG WebSocket socket (17) | Write has completed. Shutdown being performed. | 2018-06-18 09:41:01
CQG WebSocket socket (17) | Shutdown started. Waiting for graceful close. | 2018-06-18 09:41:01
CQG WebSocket socket (17) | Socket gracefully closed by remote side. | 2018-06-18 09:41:01
CQG WebSocket socket (17) | Closed. | 2018-06-18 09:41:01
CQG WebAPI | Connecting to server demoapi.cqg.com | 2018-06-18 09:50:04
CQG WebSocket | Connecting to WebSocket server. | 2018-06-18 09:50:04
CQG WebSocket socket (27) | Creating socket. Using TLS 1.2. | 2018-06-18 09:50:04
CQG WebSocket socket (27) | Connecting to IP: 208.48.16.32. | 2018-06-18 09:50:04
CQG WebSocket | Opening WebSocket. | 2018-06-18 09:50:04
CQG WebSocket | Sending WebSocket handshake. | 2018-06-18 09:50:04
CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-06-18 09:50:05
CQG WebSocket | Header line. Connection: upgrade | 2018-06-18 09:50:05
CQG WebSocket | Header line. Sec-WebSocket-Accept: S+2TGiugiLV+qTo9C09KHwAENa0= | 2018-06-18 09:50:05
CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2018-06-18 09:50:05
CQG WebSocket | Header line. Upgrade: websocket | 2018-06-18 09:50:05
CQG WebSocket | Header line. | 2018-06-18 09:50:05
CQG WebSocket | Web socket state is now open. | 2018-06-18 09:50:05
CQG WebAPI | WebSocket connected. | 2018-06-18 09:50:05
CQG WebAPI | Sending market data logon message. | 2018-06-18 09:50:05
CQG WebAPI | Market data logon unsuccessful. Server message: Username or password is incorrect. | 2018-06-18 09:50:05 *
CQG WebSocket socket (27) | Adding bytes from final send buffer from buffered socket: 8 | 2018-06-18 09:50:05
CQG WebSocket socket (27) | Initiating close of socket by core. | 2018-06-18 09:50:05
CQG WebSocket | WebSocket closed. | 2018-06-18 09:50:05
CQG WebAPI | WebSocket closed. | 2018-06-18 09:50:05
CQG WebSocket socket (27) | Sending bytes from final send buffer: 8 | 2018-06-18 09:50:05
CQG WebAPI | Disconnected. | 2018-06-18 09:50:05
CQG WebSocket socket (27) | Write in progress. Shutdown being delayed. | 2018-06-18 09:50:05
CQG WebSocket socket (27) | Write has completed. Shutdown being performed. | 2018-06-18 09:50:05
CQG WebSocket socket (27) | Shutdown started. Waiting for graceful close. | 2018-06-18 09:50:05
CQG WebSocket socket (27) | Socket gracefully closed by remote side. | 2018-06-18 09:50:05
CQG WebSocket socket (27) | Closed. | 2018-06-18 09:50:05
[2018-06-19 00:23:38]
Okay, contact your broker for help with this. This is not within our control whatsoever.
Date Time Of Last Edit: 2018-06-19 00:24:33
