Date/Time: Mon, 20 Jan 2025 14:00:59 +0000
Zigzag indicator suite inconsistent
View Count: 628
[2018-06-18 10:30:43]
User19165 - Posts: 346
The zigzag cumulative volume indicator is consistently marking the swing turning point 1 bar later than the zigzag indicator, given the exact same zigzag specific settings. These should probably mark the same turning point given the same settings, no?
Private File
Private File
Private File
[2018-06-19 16:34:04]
John - SC Support - Posts: 37327
These studies are working as they are designed. The Zig Zag Cumulative Volume resets at the next bar after the change in direction.
We have updated the documentation to make this more clear. You can find this documented here:
