Date/Time: Mon, 20 Jan 2025 13:57:31 +0000
back adjusted futures contracts
View Count: 973
[2018-06-16 23:43:38] |
Jason A - Posts: 13 |
How do I get back adjusted data for day session only futures contracts ? I was able to get a daily continuous back adjusted chart but it includes the 24hr data (overnight session and day session). Is there a way to have daily bars that show day session only ? thank you |
[2018-06-17 08:25:58] |
Refer to: https://www.sierrachart.com/index.php?page=doc/SessionTimes.php#DaySessionOnlyDaily Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-06-19 06:10:58] |
Ok. thank you. When I do that I only have data going back 20 days. Is it possible to use the SierraChart data service to back fill data going back further ? |
[2018-06-20 03:48:23] |
You need to use the Continuous Futures Contract feature: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
