Date/Time: Thu, 23 Jan 2025 02:28:34 +0000
Interday Chart not updating to current day
View Count: 1101
[2018-06-16 19:08:32]
Carol Rutherford - Posts: 66
Chart isn't updating and when I delete and download, it fails saying symbol can't be found on the server.
Here is the log:
HD Request # 175 | Error downloading historical Intraday data for INDU-I-NYSE. The symbol is unknown to the server. | 2018-06-16 15:01:05
HD Request # 175 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for INDU-I-NYSE | 2018-06-16 15:01:05
We have the data chart for the INDU-I-NYSE daily and it is working/updating fine.
[2018-06-17 08:12:48]
Use INDU-IND-NYSE
If still no data, then contact Interactive Brokers.
[2018-06-23 17:35:32]
Thanks for the response. We contacted Interactive Brokers and they were able to tell us that we are receiving data for that symbol and to talk to you.
Here are the logs we get for trying to get the INDU-IND-NYSE symbol:
HD Request # 249 | Downloading Intraday chart data for INDU-IND-NYSE to the file INDU-IND-NYSE.scid. Service: interactive_brokers.trading | 2018-06-23 13:18:40
HD Request # 249 | Download start date-time: 2018-06-08 13:18:39.000 | 2018-06-23 13:18:40
HD Request # 249 | Requesting a total of 15 days and 4800 seconds. | 2018-06-23 13:18:40
HD Request # 249 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1214400. | 2018-06-23 13:18:40
HD Request # 249 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-06-09 13:08:39 for INDU-IND-NYSE. PriceType: TRADES | 2018-06-23 13:18:40
HD Request # 249 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200070. | 2018-06-23 13:18:40
HD Request # 249 | Error downloading historical Intraday data for INDU-IND-NYSE. The symbol is unknown to the server. | 2018-06-23 13:18:40
HD Request # 249 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for INDU-IND-NYSE | 2018-06-23 13:18:40
HD Request # 249 | Completion time: 0s | 2018-06-23 13:18:40
HD Request # 249 | Intraday data download complete for INDU-IND-NYSE. Unique request ID: 252 | 2018-06-23 13:18:40
We also tried the INDU-I-NYSE symbol:
HD Request # 250 | Downloading Intraday chart data for INDU-I-NYSE to the file INDU-I-NYSE.scid. Service: interactive_brokers.trading | 2018-06-23 13:27:11
HD Request # 250 | Download start date-time: 2018-04-20 09:29:59.000 | 2018-06-23 13:27:11
HD Request # 250 | Disabling Intraday chart updating for symbol during historical data download. | 2018-06-23 13:27:11
HD Request # 250 | Requesting a total of 21 days and 0 seconds. | 2018-06-23 13:27:11
HD Request # 250 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 1728000. | 2018-06-23 13:27:11
HD Request # 250 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-06-03 14:37:10 for INDU-I-NYSE. PriceType: TRADES | 2018-06-23 13:27:11
HD Request # 250 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200071. | 2018-06-23 13:27:11
HD Request # 250 | Error downloading historical Intraday data for INDU-I-NYSE. The symbol is unknown to the server. | 2018-06-23 13:27:11
HD Request # 250 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for INDU-I-NYSE | 2018-06-23 13:27:11
HD Request # 250 | Completion time: 0s | 2018-06-23 13:27:11
HD Request # 250 | Intraday data download complete for INDU-I-NYSE. Unique request ID: 253 | 2018-06-23 13:27:11
Data does pull up in the chart ,but it is not current it is only showing data up to 04/23.
[2018-06-23 21:39:02]
We think the real answer is that the Dow Jones rules is prohibiting them from providing the data over the API.
If that is not the problem, then tell them to explain how exactly the API Contract structure needs to be filled out for this particular symbol.
[2018-06-25 11:23:42]
We are contacting Interactive Brokers about this. If it is a market data policy issue from Dow Jones, they should have told you that. And they also should have a single unified string for a symbol with an easy search feature on their website to get symbols. Not the inconsistency and complexity that they do for standard listed symbols.
This is the basis of our complaint.
If there is an issue with how the TWS API Contract structure has to be filled out due to changes on their side, only we can help with that.
Date Time Of Last Edit: 2018-06-25 11:24:34
[2018-06-26 17:35:00]
We apologize for the delay. We did hear from Interactive Brokers on this. You need to use this symbol:
INDU-IND-GLOBEX
This is now listed in File >> Find Symbol.
Here are instructions to change the symbol of an existing chart:
Changing the Symbol of a Chart
We did spend a fair amount of time on this previously and did test that particular symbol but did not receive data. So do let us know if it works properly. If not we will look into it again.
[2018-11-08 23:14:43]
The DOW Daily chart updates at night but is not active during the day.
The 13 minute DOW chart doesn't update at all and is stuck on data from March.
I have attached screenshots that have the symbols displayed.
http://www.sierrachart.com/image.php?Image=1541718824364.png
http://www.sierrachart.com/image.php?Image=154171887272.png
imageDow13minchart1102018.PNG / V - Attached On 2018-11-08 23:10:40 UTC - Size: 39.98 KB - 278 views
imageDowChartDaily1182018.PNG / V - Attached On 2018-11-08 23:10:49 UTC - Size: 30.04 KB - 262 views
[2018-11-09 08:02:45]
This is not the correct symbol any longer. You need to use the new one found in File >> Find Symbol >> IB Indexes.
The new symbol is:
INDU-IND-GLOBEX
Also all index symbols need to use -IND- in the middle. I is no longer supported as of 1838.
