Date/Time: Sun, 24 Nov 2024 09:08:39 +0000
Time alert ?
View Count: 2101
[2013-10-14 13:28:10]
EuropeanTrader - Posts: 290
is there a Time alert option the charts?
I would find it realy useful with news releases and as a reminder for things to check out during the day
[2013-10-14 15:58:36]
Sierra Chart - Max - Posts: 5730
You can add an alert to a chart as is explained here:
https://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#EnterAlertOnMainPriceGraph
For an example, please see example #6 here:
https://www.sierrachart.com/index.php?l=doc/doc_AlertCondAndScan.html#examples
Sierra Chart Support
Date Time Of Last Edit: 2013-10-14 15:58:53
[2013-10-14 16:26:34]
User201106 - Posts: 62
There is another way to enter a Time alert for your needs using the Alert Manager. Make sure you are on a later version like 1032. Select Window/Show Alert Manager. I suggest that you add this to your Chart Shortcut Menu for easier access. From Alert Manager select the tab Time Alerts. From there you can add your Time Alert. I suggest that you configure your Alert Sound with more descriptive User Defined Name. Configure the alert definition for sound and/or email.
[2013-10-17 06:59:29]
thanks canyon2!
