Date/Time: Mon, 20 Jan 2025 11:08:21 +0000
Copying Toolbar 8 custom configs - which file are they stored in?
View Count: 666
[2018-06-16 09:31:50] |
User92573 - Posts: 541 |
Dear Support I'd like to move my custom configurations that I've setup in toolbar 8 to another computer. Which files do I need to copy? Thank you. |
[2018-06-17 08:33:00] |
This is explained here: https://www.sierrachart.com/index.php?l=helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
