Date/Time: Mon, 20 Jan 2025 11:16:59 +0000
hi
View Count: 687
[2018-06-16 06:56:13] |
User981697 - Posts: 32 |
I am connected through the Interactive Broker and I have a quote in most graphs but I have one graph that I can not see the data, how I pass the data on the interactive quote, thanks
Attachment Deleted. 2018-06-16_0953.png / V - Attached On 2018-06-16 06:54:31 UTC - Size: 258.37 KB - 252 views |
[2018-06-17 09:56:44] |
You are using the wrong symbol for the chart. Refer to: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-17 09:58:02
