Date/Time: Mon, 20 Jan 2025 11:09:19 +0000
Replace fixed stop with trailing one
View Count: 738
[2018-06-16 04:39:12] |
User554317 - Posts: 59 |
Hi team, I want to do the following. Have a regular fixed Stop and profit target bracket on my orders. Then sometimes I need to leave the charts, and want my stop to start trailing at a distance of say 10 ticks. I do not want to use the trailing stop when I'm at the charts only when I'm not there so I don't want to enter the trades with an attached trailing stop. How do I go about this? Thanks |
[2018-06-17 08:39:25] |
Refer to: Attached Orders: Changing Attached Orders Configuration After Parent Order Has Filled Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
