Date/Time: Mon, 20 Jan 2025 11:09:03 +0000
Problem switching from back adjusted continuous contract to regular continuous contract
View Count: 778
[2018-06-15 19:36:31] |
User497609 - Posts: 5 |
I had an RTY chart that was set as continuous date rule back adjusted; after switching it to volume based roll-over non-back-adjusted, the change didn't occur, and I still see the values of the back-adjusted continuous contract, using release 1762 Rithmic Data Feed
[2018-06-15 20:05:35] |
That really is an impossibility. If you are not using one of the back adjusted continuous contract options, there is no back adjustment. It is more likely that maybe the back adjustment was not working as expected when you were using it.
[2018-06-15 20:23:47] |
This may not be relevant or make any difference but the only thing we can suggest is to re-download the data in the chart following these instructions: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data And as we said, if you are not using one of the back adjusted continuous contract options, there is no back adjustment. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
