Date/Time: Sun, 24 Nov 2024 08:43:25 +0000
Sierra Charts not connecting to IB
View Count: 1987
[2013-10-14 13:14:32]
User25244 - Posts: 123
Sierra charts wont connect to IB.
Worked Friday
[2013-10-14 15:11:25]
Sierra Chart - Max - Posts: 5730
Please post a copy of the message log following the steps here:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
Sierra Chart Support
[2013-10-14 15:26:26]
Sent Log
[2013-10-14 16:02:38]
You are getting this error:
IB: Trader Workstation 9392 or higher is required to connect. TWS server version required: 68
Please upgrade to the latest Trader Workstation:
https://www.interactivebrokers.com/en/index.php?f=674
Date Time Of Last Edit: 2013-10-14 16:03:21
[2013-10-14 16:07:12]
I have the latest version 9404
[2013-10-14 16:08:31]
TWS is identifying it is not the latest version. Are you sure you have 9404?
[2013-10-14 16:11:49]
I down loaded last week on 10-10
I will log out then log back in
[2013-10-14 16:18:09]
Try downloading the latest TWS version with this link:
https://download2.interactivebrokers.com/download/tws40_upgrade_latest.exe
Date Time Of Last Edit: 2013-10-14 16:18:21
[2013-10-14 16:22:07]
OK, TWS was activating the other version vs the 9404 that I downloaded last week
Problem Solved
[2013-10-15 14:56:13]
bercor - Posts: 30
Hello ...
I have connected with Sierra IB and it works.
At first it did not work Pioi I changed in the "instanced" the number of client ID and now it works.
The only problem is that I can not do refresch historians.
I'm going on the EDIT window and I select the last row DOWLOAD DATE, I put a date before IKL hole but does not update.
why?
greetings from Italy
[2013-10-15 15:08:13]
What is the symbol of the chart and is this a Historical or Intraday chart?
Provide a copy of the Message Log, by following these steps:
