Date/Time: Mon, 20 Jan 2025 11:15:26 +0000
line up 2 the same renko charts
View Count: 808
[2018-06-15 17:12:18] |
N!co - Posts: 140 |
Hi, #1 Me and a friend both connected to BitMex, are trying to have the exact same Renko charts we made sure we both have the same # days of intraday data to download , same max historical 1-tick data basicly all i can think of is set the same what could cause this difference ?? #2 is it somehow possible to make sure the renko bars open/closes line up with round numbers like 6500 6650 6000 whatever thank you very much !! |
Attachment Deleted. renko150_1.png / V - Attached On 2018-06-15 17:11:55 UTC - Size: 60.66 KB - 309 views renko150_2.png / V - Attached On 2018-06-15 17:12:00 UTC - Size: 36.67 KB - 304 views |
[2018-06-15 17:46:38] |
1. To make sure they are the same, you need to share the Chartbook. Refer to: File Sharing Also there is variation with BitMex data on our servers so there is inevitably going to be some inconsistencies. This is due to BitMex. Also refer to: Tick by Tick Data Configuration 2. Refer to: Renko Bar Charts: Opening Price for First Renko Bar and Alignment (Aligned Renko Bars) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-15 17:47:26
[2018-06-15 18:43:18] |
N!co - Posts: 140 |
thx !! can i change my account name for more privacy ?? |
