Date/Time: Mon, 20 Jan 2025 11:12:37 +0000
Pullback Tool
View Count: 1216
[2018-06-15 16:59:14] |
Dan the Man - Posts: 90 |
Hi, I tried to apply the Pullback Column only from Numbers Bar study on a range bar chart. But my Range bars are not displayed. I don't want to see Column 1, 2 or 3. I only want to see the Pullback Column based off the values of Column 1, 2 or 3. Regards, Daniel |
Pullback Column.jpg / V - Attached On 2018-06-15 16:57:33 UTC - Size: 233.02 KB - 540 views |
[2018-06-15 17:10:01] |
We are not understanding this at all. I tried to apply the Pullback Column only from Numbers Bar study on a range bar chart. This is not making any sense. It sounds like what you want is just not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-06-15 17:11:23
