Date/Time: Mon, 20 Jan 2025 11:29:15 +0000
Volume Difference - Historical Chart VS Minute Chart
View Count: 971
[2018-06-15 16:58:26] |
Forward - Posts: 65 |
Hello, I have built historical day volume chart and a 1440 minute chart (i.e. one day in minutes since 1440/24 = 60): why volume is different between the two charts ? For instance (see images attached here), passed 11 June 2018 volume on the historical chart was 100% correct while on the daily chart done by minutes it is completely wrong: why ? Thank you for your attention. Regards. |
volume_CME_official.JPG / V - Attached On 2018-06-15 16:55:51 UTC - Size: 250.03 KB - 262 views volume_strange.JPG / V - Attached On 2018-06-15 16:55:56 UTC - Size: 403.13 KB - 310 views |
[2018-06-15 17:57:43] |
Refer to this help topic: Differences With Data and Chart Bars Between Services / Connections / Chart Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
